Mtx 240 white edition
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms @4ohms @11.9v should do more @14v pretty sure it will run 2 ohms mono if it stays running cool with a fan. Great series of MTX. I remember a 275 running a pair of JBL 12s pretty good back in 96/97 pretty sure they were single 4ohm subs
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
742
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
I skimmed the manual and did not see any mention of a reset on that model, so bummer if leaving the power disconnected did not help. Maybe Pioneer...
4K
It happens
It happens
MN
    May 10, 2024
3toneEYZ
    May 10, 2024
