New DD Sub with Rockford Amps in a sealed box
connerprince
15
Irvine
Hey everyone, I recently bought and installed two Rockford amps, one 4 channel for the speakers, and one mono for the sub. I bought a 12" DD SL600 as well and have it in a sealed box because the ported box the shop offered were all massive. Is there anything else I might need? The shop did talk to be about the potential sound benefits of having it in a ported box but I couldn't find one that was small for a 12" sub, what're your thoughts?
The box is everything
Either have one custom made that fits your needs or if you even semi competent with a saw and a drill you can make one yourself
Its not all that hard
Its never going to sound as good as it could in a prefab box
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement.
Sealed will be .8-1.25.
That said ported has the benefit of being tuned to your listening preferences and vehicle acoustics.
The sl600 while I'm not sure without modeling the speaker in a box program will likely benifit from a ported enclosure. That said in your given airspace a ported 8 or 2 ported 6.5s may give you better performance. Maybe even a ported 10.
That said sealed isn't a bad box method it just struggles in the lower octaves imho
roger that, just got one from sonic electronix for $189. thanks for the help
18
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
So you have an 800 watt sub (1600 ios a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
84
276
448
connerprince
connerprince
Irvine
    May 19, 2024
    May 18, 2024
