Upgrade Batteries Or Alternator?
This is the sheet on my alternator. I would guess if I wanted a different output than 14.8 I could have it. True, it may only make peak power under limited circumstances but the proof is in the pudding. Or rather it’s on the spec sheet.
This one was hand made in AZ.
Why is idle rpm 217 amps, and 217 amps is clearly not until 2250 rpm? They don't even test it below 1600 rpm?? I'll have to see if I can find mine, but my Mechman does about that, but shift the curve about 800 rpm lower.
Thanks for all the replies, everyone. I ended up with the 370a Mechman. Showtime ftw.
I just installed the alt and got a smoke show. Melted a wire when I turned the key. I don’t suppose anyone has an idea what the problem is?
That pigtail doesn't make sense to me. Is that the way it came? One should have been a low voltage power/switch wire, and there needs to be a ground wire. I'm really puzzled why the pigtail wire would go to the same bolt as your charging cable.
My mechman came with a pigtail. That wire that goes to the charging bolt, did you cut that and add the terminal ring to it? Was it about 5 feet longer, and you just cut it short?
Where is your alternator grounded? Did that just become your only ground? (I don't even see a grounding cable for your alternator).
Not sure why I didn’t get notifications to this thread. Anyway, that harness is exactly how I received it and the directions said to hook that wire to alt charge post. 🤷‍♂️ I guess it’s a voltage sensing wire.
The problem with my install was on a 6.0 Powerstroke, the alternator to battery cable feeds the glow plug circuit so when I removed that cable, somehow my glow plugs (>200a) tried to charge through that 16ga wire 💨 🤣
The alternator is working great now with the original alt cable reconnected. 👍
Im seeing a steady 14.4v until I really crank the volume, I can still drop to 12s at idle. At higher RPM, no problems. Actually, at 2000RPM (engine) when I crank it, my voltage went UP to 15.3v
Also, the alt is grounded to battery and cab. You can see the cables at the rear left mounting bolt.
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
448
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
560
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
767
Colorado springs
    May 16, 2024
    May 16, 2024
