Old Pioneer head unit and line out converter question
jlatenight
I have an ancient Pioneer head unit that only has 3 speaker wires. It's an old Jeep requiring a shaft-mount stereo (mounted by the knob shafts), and I don't want to cut the dash for a DIN. There's +L and +R, but only one negative wire out of it. You're supposed to wire the negative to one speaker, then jump that terminal to the other speaker's negative. Obviously the LOC has 4 wires. I tried twisting the two negatives together on the LOC to the single ground on the stereo, but there was only sound from one speaker. I have a feeling I might be screwed. Anyone know how to deal with this?
White Line Font Parallel Rectangle
Rectangle Font Parallel Slope Pattern
Welp, I wired-up the Floating ground adapter, but it didn't work. I was told to use it backwards than typically used. It's usually for a modern stereo to be installed into an old vehicle with speakers grounded to the body. I have the reverse problem. Only one neg speaker wire coming out of the stereo. Can anyone help me? I would be forever grateful!
Their are options. It depends on how much you want to spend. Some of the ‘floating screen’ head units could be adapted for an old car without cutting the dash. My Joying head unit uses a ribbon cable to connect the screen to the main unit. I believe that they sell extended ribbon cables that would allow you to mount the unit behind the dash. Then put the screen where the stereo sits. Of their are companies that offer 2 shaft stereos for classic cars.
https://customautosoundmfg.com/
Much appreciated. Maybe this will help? I'm looking for an easy cheap solution to this. I just need to make a single speaker ground out of the radio to 2 separate grounds (negs) on the LOC.
46753
So look around on eBay for a unit like yours but with RCA outputs on it. Some of those shaft older radios like that in the '90s had RCA outputs on them. I know I had a Sony as a cheap option once and it had a pair of RCA outputs on it for adding in an amplifier like you want to do. That way you don't need the LOC.
Honestly, here is what I would try. Those old 2 channel radios didn’t put out a lot of power. Forget the LOC. Connect the wires from the radio directly into rca cables, and then run a ground loop isolator.
Yup. 3.2 watts is less than 4 volts.
It worked! I have it hooked up to the amp and it seems to be working well. Thanks so much for the help.
I do have one issue with this ancient Pioneer HU. the left side is louder than the right. The balance control obviously helps, but there's def something wrong with the HU itself. I was hoping there was a pot or other control inside it I could adjust. Is there such a thing?
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
jlatenight
jlatenight
py@Ou2^Mm9mE
dragon.breath
    May 16, 2024
    May 16, 2024
