Question about gain and tuning a Lc7i and 5 channel Amp
Correct. From the amp, disconnect the RCAs that come from the LOC. The picture below points to where you will connect your multimeter test leads. Be cautious that positive and negative do not touch each other. The guy in the video made that pigtail to avoid this issue. Set multimeter to A/C volts. After downloading that 1000 Hz. test tone, play it on your radio at ~75% volume. Now sweep the gain on the LOC until you read the 5 volts that your amp can handle. Boom, Jalapeno solutions. Before reconnecting the RCAs to the amp, turn down the gain at the amp. Turn it up judiciously after that with the radio at ~75% volume.View attachment 47064
So I have an amp that has an input value of 14v and my LC2i has a 9.5v preout. I wouldn’t have to worry about testing with a DMM (as shown) to set the correct gain on the LOC. I would just put the gain all the way up on the LOC? And keep the gain on the amp as low as possible?
Strangely, the more I know…the more I don’t know. On previous builds I would just wing it and push some buttons here, turn some dials there and call it a day. 🤣
Correct.
No. For the sub amp's gain setting, you go by the sub you will be using. Formula for that is-
A/C Voltage= Square root of Watts × Ohms.
If you want your 4 Ohms sub to play 300 watts. 4 × 300= 1200. Square root of 1200= 34.64 A/C volts.
Yup, I know that feeling all too well.
Yup, this too.
Correct.
Yup, this too.
Thanks for the info! Super excited to finally dial this stuff in after 25 years of winging it.
481
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
780
bando81
bando81
CALIFORNIA
chornet44
    May 12, 2024
    May 11, 2024
