3 way passive crossover help
GoT_2B_BuMpN
Hello, I am looking to get crossovers for my SKAR dual 6.5 in doors which are wired together for 2ohm. I also have 1 midrange and 1 tweeter in each A pillar. The crossover has to be 2ohm capable. Any ideas on where to buy? I've looked on a lot of online places and can't find. I'm new to installs, so I need help figuring out how to properly wire my system
Selling a Helix V1 for 300 plus shipping.
If not interested then Helix, Audio Control,Mosconi, Focal are probably the top of the line ones, mid level then Rockford Fosgate, JBL has a nice one 8 channel out there with 8 channel built in iirc but they are hard to find. Dayton is the probably the best of the cheap bunch that is out there.
I got a Mosconi DSP 6to8 V8 I'd let go for 250.00 shipped as well.
But if you want new, would need to know your budget, Prices range from a couple hundred to over a grand.
If you still want passive, eBay user Mavin has extensive knowledge and a few options.
Electronic crossover or a cheap DSP. If all you’re using it for is crossovers and you won’t be using time alignment, parametric EQ etc., then you don’t need an expensive DSP. I have a cheap PRV DSP that works fine.
Yep. It would be a little over 3 wired in series, but that’s fine.
839
Also if you did decide to get another amp the output rca on the amp can be adjusted with the internal dsp
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
782
GoT_2B_BuMpN
GoT_2B_BuMpN
No Conway, New Hampshire
Jimi77
    May 19, 2024
    May 19, 2024
