How do i Connect two 2ohm Speakers and one 8 ohm speaker to the same channel on my 2-4ohm amp?
I don't think it's that easy to answer "for a complete beginner".
amp and speakers ratings are those peak or RMS?
Are these already installed?
There's a chance it might be better to wire that differently. Especially if there's not pass filters or crossover involved here. I would want to know if wiring the 8 mids in series so it's 2 mids per channel on that amp. Then separately wiring the tweeters in parallel so it's 2 tweets per channel and either running something around a 70w x 2 little amp for those, or if you have a 50w x 4 head unit that would be perfect for those. This way would allow you to add pass filters either inline, on the amp, or even on the head unit to really control that frequency range on all the speakers. I would be really hesitant about just wiring tweeters up with mids without a filter/crossover.
375
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
529
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
Kevinrd01
Kevinrd01
Norway
HardofWhoring
    May 16, 2024
    May 16, 2024
