Eq install help plz
I no how to install a the EQ getting the signal from the door spkers. Can I jump off the line out converter from the amps signal?
The amp is only powering the sub. How do I get the EQ to control the levels on all interior and sub aswell
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
That or with a TB, you either have an amp, or those early 2000 years on the full size tahoe, they were wiring them in series. It's most likely...
That makes sense to me, I was afraid if I bypassed those and messed up setting the others I may damage my component speakers. I'll play with it...
chow2176
chow2176
Pa
HardofWhoring
    May 24, 2024
