cb045
I just installed kicker speakers into my truck. I made sure and had very strong connections to the speaker wires. I have a four speaker system, and my left two speakers are way quieter and sound way worse than my right side. I think maybe a polarity issue, but where? Thank you.
What is the whole setup? Aftermarket radio, 4 channel amp, speakers?
How were the speakers installed? Are you using an after market HU. What vehicle ? More Info needed
Im using an aftermarket head unit, its the Sony Xav-ax150. My speakers were completely blown before. The left side was always quieter, but i didnt think anything of it because the speakers were shot. It does not have anything to do with the speakers though. And yes, i made sure my balance/fade was in the middle. 2004 Sierra 1500 Ext cab.
I am not using an amp, as of right now. The HU is a Sony XAV-Ax150. Kicker DS series speakers, 6.5" in front, 4x6 in back. 2004 Sierra 1500. I replaced the speakers because they were blown from previous owner. The left side was always quieter, it has nothing to do with HU or speakers. Yes balance/fade is in the middle. I am going to trace back the speaker wire to see if there is any issue this afternoon.
2004 Sierra 1500
Inside above the e-brake there is a harness that connects to all the door's components. Worth checking. Also just in case, check that you did not connect the 6.5s to the tweeter's wire, it may have an inline capacitor. If nothing pops up, check the wiring inside the accordion between the cab and door frame.
Ok, thank you. I used the wire that ran to the factory speaker, so i figured it would be alright. It is sounding good, just very quiet.
I cracked it all open, what am I looking for? Could it be my stereo?
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
304
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
442
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
241
38
cb045
cb045
Colorado
cb045
