Image Dynamics?
Actually that would turn me off of that company if they lie about the specs. I figured a nice 1000 watt rms amp would do it and then to find out it won't work as well. Glad I posted this here. Ty
They are not "lying" about their equipment. Most quality builders leave head room on their subs so if you F something up and throw too much power at them they will survive. Then you have some guys who like to push them to the max and will figure out the limit. Most quality subs will play at their "max" level for short bursts, which are called SPL burps. If you have SQ in mind and want longevity always go by the rms value, builders make this the set point where the sub will play its best with the clearest sound and maximum spl at the same time without failure.
Agreed. I love SQ but I'm a basshead at heart
So the 1000×1 at 1 ohm into 1 idmax 15 would work fine?
I could swear Ive seen those years ago. I wouldnt waste money on it
112
9K
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
Battery expert 2023
Battery expert 2023
Antarctica
Marve_Lous
    May 12, 2024
    May 11, 2024
