Loss of local stations ( both AM&FM) when motor running
Is it an aftermarket radio? It may have something to do with the remote antenna wire.
Hi, thanks for your reply. Yes Kenwood DDX375BT , no remote antenna wire. Weird that only far away FM stations work. Old Kenwood worked fine.l even placed antenna remotely away from car.(about 10 ft) David
Was a radio adapter harness used for plug&play, or was the OEM harness clipped off?
Hi again, old radio adapter was used and checked a dozen times. Every thing is ok. Tried to wire and ground directly to battery, Same results. Even swapped out motor spark plugs and wires to different RFI
types , no change. Even Kenwood has no answers?
Hi, no shark fin. Have standard car antenna. Double check fit and continuity. 1992 Mustang
I was thinking about this and just recalled on one of my stints we had radios. I could knock out another's radio station by messing with my tuning while seeking a station. This may apply to your situation since you say the further stations still come in. Some RF inducing device is kicking on only in run mode. What kind of mods/upgrades do you have on the Mustang?
Again, thanks for helping me. It
has a lot of upgrades (super charger , heads,etc) Has MSD
ignition (all rfi complyent). Nothing else wood cause interference.
Besides the old Kenwood worked great.
MSD
ignition
Aha! The smoking gun. Newer radios seem to be more susceptible to RF noise. May be part of the planned obsolescence agenda. RFI compliant means they can receive noise but must not emit it. But at that range I do not know if it is acceptable. I think High Flow fuel pumps also emit RFI. You may have to sacrifice yourself and settle for Bluetooth or SD Card.
BTW, a picture of that 'Stang would be neat.
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
Hello! are you found the cause? I have similar problem. Sound like Sh*t bass :/
Nice find. Generally always an issue at a Break /Spliced area. Ikeep approx. 4-6 inches of wiring on each side of a main Fuse to refresh to Clean...
13
The next time it happens check the voltage directly at the Boss radio. If it has 12v on both the red and yellow wires and the black wire is...
636
If you had to run new wires that tells me the old head unit was fine and that there is a break someplace in the wiring you have now. I would be...
27
DSM studio
DSM studio
Nj
Silicon oxide
    May 8, 2024
    May 8, 2024
