lithium
prizm01
30
maine
alright i have given into the temptation and would like to try lithium, however i have a 400 amp alt with an internal voltage regulator and was wondering if i can run it at all with my current alt, not looking to get get voltage up just get some serious AH. would i have to use a charger? or would i be better off finding batteries that are the right voltage to charge right off the alt? what would be better for long play time at shows doing demos all day?
What is your alternators charging voltage? Under 14.8 or above?
Lithium would be charged with the alternator just like any other battery.
What amps are you running to decide how much lithium you need.
taramps smart 3k bass and rockville db45 4 channel, i plan on upgrading to a bass 5k soon so have to also keep that in mind, the alt charges at 14.9 to 14.7 on the button
How are lithium batteries in your knowledge base? I'd take a hard guess and say they ain't mentioned in your book from the 90's 🤣🤣🤣
I don't see one that would be even okay for car audio application.
Well then, guess I missed something, could of sworn I did them due diligence. What spec's (regarding charge and discharge rates) are you refering to as inqdequate? I could have ovcerlooked a spec. or two...
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
  • Locked
I think the guidelines want members to have a picture with your forum username and current date in the picture to avoid scammers. :)
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
How often are you charging? I charged mine once when I built it over a year ago and maybe a couple times while I had the car pulled apart. I...
prizm01
prizm01
maine
    May 31, 2024
