Need help with wiring subs and amp correctly.
Mission Shane
Ok so here it goes.
I have a Kenwood KDC-BT848BU head unit wited to the 4 reg speakers and a MTX Thunder 400w 4 ch amp running to 2 old school Phoenix Gold 8" subs 200w each but 4 ohms. The amp is bridgeable. With the subs being 4 ohms, what are my options? I don't wanna burn out the amp. Although older, it is brand new. Was bought and never used. Do i run them in parallel to a bridged amp? Or just straight wire one sub to one channel? I'll be replacing the subs soon. I just don't know with what tho. Thanks in advance
Yes! It will be 200x2 @ 4 ohms Bridged by specs
Thank u. I was told I'd fry the amp. Was told it would run at 2 ohms not 4. Says right on the amp (bridged 4 ohms". So then i could technically put 2 of these in and it won't cook the amp?
Yes. You want to wire each sub to theyre own Bridged chs. 2 the amplifiers 4ohm stable load. And make sure that you place your crossover switched to LP/LPF,. Off your HU, the Sub RCA, run one set of RCAs to the amplifier(be 2ch) and buy a set of Y RCA splitters and feed the single into 2 RCAs in from the two ch RCAS to make it 4 of left and right chs so the channels on the amplifier are getting signal from the HU off the Low/Sub RCAs
Those are SVC 4 ohm subs,. You can run those on that amp. Sure as hell can!! You can run One sub on each Bridged 2 ch @ the Final 4ohm load for each sub. Just tune properly out of distortion at max HU volume on the HU and you should be just fine. not sure where you are getting your information from, but I would not listen or take any more advice from that individual any longer. Good to see you are doing your research to get some facts
Lol thats why i came here lol. Thank you. This is correct? Now just split the input so all 4 rca jacks are full?
I would recommend an OFC 4 ga wiring kit for that amplifier to supply for the demand. Old school amp need to be fed to perform as most A/B amplifiers do.
(2)RCA Splitters needed to get from 2 ch to 4 ch on the amplifier from the HU
Thanks man. Going to get 2 splitters now.
Ive got an 8 ga in now but i am going replace it when the new subs go in
Yes.. Make sure that you have the + and Neg wires for the sub in the Bridged correctly and make sure that you have the Xover set to LP/LPF. Make sure your gains on the amplifier are set to bare min, and you can tune from there properly so you dont cook a sub coil. LOL, and yes on the Y splitters for the amplifier
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
564
685
Mission Shane
Mission Shane
Mission bc Canada
    May 12, 2024
    May 11, 2024
