JVC KD-R420 Faceplate not working
Got a JVC KD-R420 off of facebook marketplace and when I gave it power the the screen never turned on and nothing lit up. The only thing on the faceplate that worked was the cd eject buttom.
The risk of purchasing on Marketplace. I have gotten some great deal there, but never purchased any electronics. Try contacting the seller. If no satisfaction, throw it in the trash and purchase from reliable business.
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on correctly. If it doesnt, then its trashed. Hit the Reset button also to make sure. hold for 5-10 seconds on the reset button. If it does work, then you have an indash wiring issue to solve
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Boom_Dude_07
Boom_Dude_07
Calgary Alberta
    May 12, 2024
    May 11, 2024
