COMPLETED Focal FPS 2300RX $275 Shipped.
  • 2
Premium Member
Current build, 2012 Mazda 3 Hatch 2.5T
2,107
761
Boise, ID
Price
$275.00
Condition (1 worst - 10 best)
Nampa, ID
Hello everyone, selling one of my Focal FPS 2300RX amplifiers. I purchased two of these from Woofers Etc. Directly for $349.00 each. This one is pristine. It's never been mounted and was from a glass display case. It has the BASS knob and original box and packaging. A few of you probably noticed the system I am building and the evolution of the build design (okay the inability to control the fast button-clicking purchasing finger when I get an idea). I've finally settled on using the AC 4.300 and my focal FDP4.600 and going fully active and that leaves this amp out. As much as I would like to use it for the front stage, 155 watts per channel at 4 ohms for the tweeters is just a bit overkill. This amp is versatile and powerful, clean and dynamic. Everything about it screams quality. MSRP on these was $1400.00. Will throw in a DS18 4 AWG mini ANL fuse holder and 2 fuses.
Some info:
  • Symmetrical design: Audiophile Quality
  • Progressive controlled cooling system: Regulates the amplifier temperature
  • Insulated Gate Bipolar Transistor (IGBT): Audiophile and powerful
  • Direct mode: The audio signal is directly amplified
  • High-pass, low-pass and band-pass crossovers: Adjustable from 50Hz to 5kHz
  • Pseudo-balanced input: No parasite
  • Controlled cooling system: Airflow control
  • Safety terminal: Cable and sheath complete integration
  • Remote control,
  • Stable into 1 Ohm,
  • High-Cap compatible, Full Mosfet
  • Dual monoaural power supplies
  • Amazing Build Quality
CEA 2006 (4 Ohms, ≤1% THD+N, 14.4 Volts)2x155W
Nominal Power2x200W into 2 Ohms with 0.04% THD
Nominal Power2x300W into 1 Ohm with 0.05% THD
Nominal Power (bridged mode)1x410W into 4 Ohms with 0.03% THD
Nominal Power (bridged mode)1x600W into 2 Ohms with 0.04% THD
Adjustable high-pass crossover from50Hz to 5kHz
Adjustable low-pass crossover from50Hz to 5kHz
Adjustable band-pass crossover from50Hz to 5kHz
Direct Mode: Protectionsshort-circuit, direct current, thermal overload, polarity reversal
Was Photo Included
  1. Yes
Dammned!! Good looking amp! Be perfect for front stage for sure or a single DVC4 ohm sub!! Fan cooled too!!
I know right? Wanted desperately to keep them for the front stage, just ran out of room as the design of the build evolved. The AudioControl 4.300 (tweeters Frt/rear) and Focal FDP 4.600 (mid-bass Frt/rear) combo should be okay, well, a little more than just okay, just not as pretty! It's one of those products that you know sounds good just looking at it!
$2500usd package Shipping and PayPal fees extra I have a nice sub and 3way system available. All BNIB If you need more than one sub or rears...
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
Excellent set of speakers if they're in good condition. I ran the home audio version of that midbass driver for a while. Still have them in my...
13
  • Locked
Looking to buy these sir! Pm me - I requested you on IG
Premium Member
Boise, ID
    May 12, 2024
    May 11, 2024
