Blackbrick 15" sub
  • 5
Looking at the pics, I can tell ya now those lead wires will be slapping the snot out of the cone 🤣
No no no, it was designed that way. As the sub breaks in, the coils burn off excess and become more prone to heating. The extra travel allows those temperature management prods to install new heat management vents on the back of the cone. Very high tech indeed.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
113
279
460
557
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
885
Junior Member
Pharr, Texas
spokey9
    May 19, 2024
    May 19, 2024
