do i use an lc2i-pro if i have a PAC APSUB-GM61
  • 2
You would use the Lc2i if you are doing an all speaker upgrade + sub w/external amplification. If you're just adding a sub, the PAC is all you need.
Your post was not specific enough so the reply was general too. Are you simply adding a sub or multiple channels of amplification? What exactly are you intending to use either of them for?
I'm using the PAC to get the signal from the factory head unit. There's a bose amp. I just want to add a mono amp and a couple 12's. I have both, the PAC GM 61 sub pro and an LC2i-Pro. I'm wondering if I should use both if I have both.
thanks for your help
Then all you need is one or the other. Run the low level outs to the one or the other and the RCA's to the sub, tune it to cross to your liking, set the gains accordingly and you're good to go. Personally, if you have not installed either yet, my preference would be the LC2i for that added feature set and performance.
Thanks for your input. Since I already spent all that money on the PAC i would hate to not use it, ya know?
Can i use both and still get the extra features from the lc2i? Ive never tapped into speakers before, so i'm kinda wanting to use the pac so that I dont have to do that
Nope, Either or. If you own both, then it's a loss on one or the other less what you sell it for, right? The PAC is an easier install and that should be all she wrote!
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
Has anyone ever used one of these for a line level output from the head unit (aftermarket, not OEM)? I saw a past thread about changing jumpers on...
Okay so for the basics, No I do not have a factory amp, or any other amp installed. I only have the one amp to power my subwoofers. I have not...
657
  • Locked
I no longer have the car I had this LC2i hooked up in. I got about of year worth of usage out of it and had no problems. New LC2i model sells for...
boscher50
boscher50
idaho
    May 12, 2024
    May 11, 2024
