Different Impedance Between Front & Rear Speakers
  • 2
Rajo Alam
Dear friends,
I just replaced my car front speakers with impendance 3 Ohm. I have stock coaxial speakers with impendance 4 Ohm and plan to install replacing the oem. My questions are:
1. Would be a problem if the speakers impedance are different between front and rear?
2. Is there any electricity risk that impacted to the wiring?
3. Would it impacted to HU, for example the increasing heat?
Kindly please advise.
Many thanks in advance 🙏
Only difference I can think of would be the front will be slightly louder than the rear but that can be adjusted with the fader.
At such a minimal impedance change you should not have an issue.
It should be ok.
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
Rajo Alam
Rajo Alam
Indonesia
Rajo Alam
    May 8, 2024
    May 8, 2024
