Hi SQ 10 recommendations
Checked out for a bit, came back to a bunch of redacted posts!
If 1000 is ideal, I may be better served with two amps. JL handles 1000rms as well, but they show a sweet spot where it’s ideal which is below the rms. Sounds like the Brahma isn’t the same…
They list dual 2 and dual 4 as VC options. What are the basic reasons for picking 2 vs 4?
Since you're just using 1 sub in the center console, you would buy the sub that works best with your amp. Assuming your amp is 1ohm stable, get a dual 2 and wire it in parallel. If your amp is only 2ohm stable, get a dual 4 and wire parallel.
Not sure what that means as of yet. This is a snapshot that may provide some answers:
I think that he's considering the Sony XM-5ES 5-channel car amplifier
  • 100 watts RMS x 4 + 450 watts RMS x 1 at 4 ohms
  • 165 watts RMS x 4 + 750 watts RMS x 1 at 2 ohms
  • 330 watts RMS x 2 bridged at 4 ohms + 750 watts RMS x 1 at 2
That could work. Albeit a little underpowered and for the price, I'd do a couple of other amplifiers.
Suggestions?
I’m open to suggestions on the polks. They looked like a decent speaker based on power and I filtered results based on have silk tweeters. I may be wrong, but I thought I read silk was the way to go for SQ.
I could probably fit the amps behind the back seat, but it’s pretty tight. I’ll have to look tomorrow. It’s a 2004 ram quad cab. They squished the back seats pretty tight to the back wall. I believe they get even closer when the back seat base is folded up. I can relocated the factory jack that lives under the passenger seat. The center jump seat that’s getting removed for the box is 15”W by 20”L and I want it to be pretty close to the 15” tall that it currently is when in arm rest mode.
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
848
Doors and dash? Year, make and model of the car? Amplification? Midranges or coaxials? Need some more specifics about what if anything is already...
567
Heck...done right...you could get an amazing sounding stereo using $15-25 drivers from partsexpress 😂
952
29
A single 10 or 12 tuned will do fine in that vehicle on a nice set of components and coax in back doors for passengers
GoldCountryCA
GoldCountryCA
Northern Ca
Old_Slapper
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
