Box design for dual xfl 12-44
  • 2
basshead79
Mars
i want to buy a design for my
2 American Bass xfl 12-44
I saw a similar post with a design thats 17"H but i need a 14"H box
so i'm looking for a
Front slot ported box 33 hz and about 2700watts 1ohm
38"W 14"H 24"D
going to be facing rear in trunk of my sedan if that helps
Any help would be much appreciated
  • XFL-Series.pdf
38"W 14"H 24"D
Box External Dimensions
Width x Height x Depth
40.00" x 14.00" x 22.94"
Material Thickness0.75"
Net Internal Volume4.50 ft3
Tuning Frequency33 Hz
Port Area72.00 inch2
Port Inlet
Width x Height
5.76" x 12.50"
Port Length29.22"
If you need to, just change the dimensions accordingly but maintain the same port area so the tuning stays the same.
- OR -
Get one of these (at the tuned frequency desired) and lay it on it's back
339
668
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
674
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
basshead79
basshead79
Mars
basshead79
    May 8, 2024
    May 8, 2024
