alternator battery
  1. T
    2018 Honda Accord / Voltage regulator / 14.4v
    I'm a newb when it comes to power so forgive me... :) Thanks in advance! 1.) Is there a way to bypass the voltage regulator so the alternator chargers 100% of the time without a CEL? Right now I have to drive with my lights on which isn't the end of the world but figured I'd ask. 2.)...
  2. DarkKnightSM
    Need a good multimeter to test amps, and Volts
    Im trying to figure out the wattage my amplifier is putting out. I want to make sure its able to feed the amount of power im asking of it and just curious i suppose. Its rated at 1000watts rms and i imagine im pushing it pretty close but im just guessing. So to figure watts i need volts times...
  3. M
    Alternator and battery help
    Okay so the amps I have are sundown audio scv 3000d and a rf t400x4ad. That's a total of 3,400 watts. Now if I purchase a 270 amp alternator and a d2400 xs power battery (3500 watts max amp) as a second battery from my stock one will I be able to run 3,400 watts easily? And my alternator won't...
  4. K
    Major voltage drop when barely playing Subwoofer
    3500w 15' Crescendo Audio CrossFire Custom Sub 4' voice coil Hifonics Atlas 6k "3500@1 ohm" Crescendo Concerto 1200/4 2 Crescendo Deep Cycle AGM F-34HP Batteries 2 Kinetik 1200 AGM Batteries 2 Crescendo Neo's 6.5 4 Crescendo PWX 6.5 2 D-250x Horns Stock Alternator Stock Battery Under...
  5. bs199sg
    Looking for new alternator
    I am looking for an alternator that will easily charge up my batteries. I have 2 XS Power D3400 XS Series 12V 3,300 Amp batteries. I am running at max of 4600 watts out of my current system. Not sure how many amps I need for an alternator. I have a 2007 Ford Focus 2.0l Duratec engine.
  6. bs199sg
    Alternator/ battery upgrades
    Hey all, I believe my alternator and or battery can't supply my system with enough power. My total wattage is 6000 using stock alt/batt. I have a 2007 Ford Focus SE. If you coule point me in the right direction or give me some ideas of what to do with it would be great. It started with my subs...
