Alternator/ battery upgrades
  • 4
Hey all, I believe my alternator and or battery can't supply my system with enough power. My total wattage is 6000 using stock alt/batt. I have a 2007 Ford Focus SE. If you coule point me in the right direction or give me some ideas of what to do with it would be great. It started with my subs clipping, and my headlights dimming with the bass.
6000 watts on a stock system would shut your vehicle off //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. Start off by looking into a high output alternator
Sent from my Z970 using Tapatalk
Yeah doing 6k on a focus is bs lol...I' am running 2600 rms on 2 batteries and a h/o alt and my max is probably like 4600 peak if that.
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
981
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
7
From what I've read, LiFePO4 works with lead acid, LTO does not. I have only personally tried LiFePO4. I personally can't justify the extra hassle...
I'm not an expert on Lithium by any means. All I can say is I've played my system for about 2 hours at about half volume(20/36 on the headunit)...
8
bs199sg
bs199sg
United States
bs199sg
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
