07 Chevy Colorado install
Its hard to cram all that equipment into such a small cab.....looks good other than im not a big fan of your tweet placement.....hows it sound? You should be creative with where your amps are now...just build a rack and then a trim ring around it and maybe some neon or mirror or both.....good luck!
basically if you place the amps on a piece of MDF or something and put another piece of wood over them to "cover" them up in a sense, but you obviously cut out the spots in front of the amp's so that you can see them. Looks good by the way //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The imaging from moving the tweets from the upper part of the windshield to the bottom did not change a lot IMO. However, the comp set and that kicker amp makes a world of difference.
Good install joe //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.... Now its time to make that rack
little FYI.... This should be going on the TL tomorrow around noon- results will be posted.
I'm thinkin 140ish due to box tuning and volume.
sorry joe, youll never be as loud as me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You should b louder than you actually are //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
lol im at 135.5 now..... got rid of the vdub.... im runnin one power acoustik fubar 10 w. a kx750.1 in a cute pink box
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
742
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
Jo0ee
Jo0ee
Jo0ee
Brockport, NY
flipside1212
    May 31, 2024
    May 24, 2024
