10 inch sub suggestions
  • 4
Ack
Hi am looking for suggestion for new sub, recently decided to get back into car audio I have been out of car audio for about 10+ years so I have no clue what companies are good now a days . I am currently running a kicker comp vr (old sub I had from long time ago and one of the only things didn’t sell when I sold all my stuff) with a kicker 600.1. Sub is dual 2 ohm so amp only running at 300w. I think the sub is getting ready to die so I want to get something to run the amp at 2ohm so sub would be 600-800rms preferably one 10 inch sub and I have custom box in my Jeep Wrangler that I would like to reuse aprox 2 cubit feet sealed thanks
Yes the info I found online said could go up to 3ft2 for the sub and just wanted to add I looked at box and could probably make cut out bigger so maybe a single 12 could work as well
That is massive for a single sub, regardless of 10" or 12" cone. Good news, its easier to make the inside smaller than make it bigger. :)
So you are saying I should add some wood inside the box to take up some room , also I might be thinking to go with two 10s then I could keep the box that size , any suggestion on good brands that won’t break the bank , thanks
I am biased as I co-own SSA. So our SSA Demon 10's would be my first suggestion. ;)
Thats a good looking sub. Ive book marked that site. I may try one out for an Xmas present to myself??
50
5K
Yeah I’m up ****’s creek. OP has gotta be more specific about his equipment and what he wants, IMO. 10’s take different boxes, so it’s hard to...
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
This. It's hard to beat for the money. They can take a pounding. Make sure that your amp is one ohm stable. If it isn't the buy the dual 4 ohm sub...
991
Ack
Ack
Montreal
fithwheel
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
