15" Soundstream XXX or 15" AudioPulse Axis by TC Sounds *PICS* ADVICE NEEDED!
  • 3
SHiZNiLTi
What sub should I buy, I have (2) to choose from...
15" Soundstream XXX quad 1.2ohm coils (reads 1.4ohm though)
or
15" AudioPulse Axis Dual 2ohm by TC Sounds with 3" excursion (would wire to 1ohm load)
Powered by a hifonics bxi2008D @ 2krms - 1ohm
Kinetic HC2400
1/0ga Kicker
140amp alt
I know either sub will be under powered with what I have, but I'd still like advice on which to get.
Thanks!
Going in this box...
Net Volume: 4.06 cu/ft
Tuning Freq: 38.56 Hz
Port Area: 64.13 sq/in
Box: 34" wide x 15" tall x 22" deep
Port: 4.75" wide x 13.5" tall x 16.5" long
15" AudioPulse Axis by TC Sounds...
15" Soundstream XXX...
The XXX will lulz at you with 2k. I had an MT that kept up with a XXX in my CRX until >5k was applied, then the XXX started walking it. Not much info on the Axis, sorry. I'm an SS nuthugger and would probably try the Axis on this one.
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
SHiZNiLTi
SHiZNiLTi
Scottsdale, AZ
CRXBMPN
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
