1x SQ HDS3 12" 2R DVC vs 2x Kicker CVR 07CVR124
  • 4
Are you going for peak spl or daily with a wide frequency range? What kind of music do you listen to and what vehicle?
This would be installed in a '98 Mercury Mountaineer. Daily driver in winter. I mostly listen to rock/metal. Space is not issue really.
What is an HDS1222? You mean HDS2 12"?
I was thinking of the XFL 1222. This is an HDS3 12" 2ohm dvc.
The HDS3 and XFL would be underpowered on that amp if it does 1200rms before rise. The two CVRs would definitely be louder.
You could get two Sundown LCS B stock 12s for $72 each.
Thanks. I typically just use a slot port. Assuming that's okay. Not sure if you were simulating that or just glanced at kicker's specs.
Only time I use a slot is for a low volume low tuned box where you need a long ass port and an aero isn't practical.
Overall aeroports are more efficient and easier to design and build. Up to you if you want to use a slot port. If you choose a slot then use 14-16 sq inches of port area per cubic foot of volume which is 56-64sq in of port area for 4cf@40hz.
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
502
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
cas0586
cas0586
WV
THATpurpleKUSH
maylar
    Jun 2, 2024
    Jun 1, 2024
