(2) 12" DD 2512 on 3000 RMS??
You can always turn the gain down a bit more, and keep an eye on them. Otherwise, wait for another good deal that better suits the power you have on tap.
So you don't think it can handle around 2500? I just want to use the woofers to its potential without any clipping.
I will say that my old dd2510 took everybit that my aq2200@2ohm could muster. I did end up ripping the spiders but that was my fault for dropping way below tuning. So can the 2500's take power why yes they can but at those lvls you better be sure you know what your doing..
Wow that *****. Appreciate the help..
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
997
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
But since you guys are still here, I have another question. Now that I have a 3k amp, after I get my new battery and HO Alternator, I'll be in the...
272
20K
swollen_cu
swollen_cu
New Orleans
thegreatestpenn
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
