Good SQ but with loud bass?
boddy
I haven't saw most people with a setup like this, most of the SQ setups i've seen only have like an 8" sub.
When i'm finished i will be running a set of Focal 165V30's active off a Genesis Profile 4 and a FI Q12 off a JBL GTO 14001, haven't decided on a headunit yet but i need to upgrade to run active. Removing my rear speakers aswell so it don't ruin the imagining.
Just wondering how it will sound?
Are you installing yourself or is a shop doing it for you. You can run the best equipment and not have the sq you want/need based on a bad install. Make sure you take time and go over all the facets of proper driver alignment and deadning if needed. Install, like everyone preaches, will make or break your sound. Be patient and do it right the first time. A properly set up system will do your ears justice in the long run and be a fun past time. You do have a very nice equipment list so install all of it correctly and you wiil be happy!
It depends on your EQ and enclosure. It could sound great and blend well or stick out like a sore thumb. The biggest thing I would be worried about is getting your mids to play as low as possible. The sub will become directional if you have to play it higher to make up for midbass. I would try to shoot for 45-50hz low pass on sub.
Are you looking for vehicles to compare to ??
I know of a truck that has a 2 way passive component set on ALOT of power, center, rears, and 4 10s isoberic on ALOT of power ...
This thing JAMS and has **** good Sound Quality to boot ...
SQL has been my goal for most of my systems
My current system is a Set of High End older MB Quart Componets in well deadened doors running on 200 RMS each channel
High End Pioneer Head Unit
And a set of 12's on 1,500 watts with a bass knob
Most of the time the knob is down low and I have a nice front stage with good mid-bass
But then crank up the bass and it gets loud.
That is how I like my systems.
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
4
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
boddy
boddy
birmingham
>>SQL<<
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
