2 Amps, After Market Radio, and Input/Outputs
  • 2
Newb4Lyfe
CarAudio.com Newbie
Please bare with me here this might get a little long.
First, Here's my setup:
1. 2005 Mazda MPV LX
2. Jensen VX3016 7" Single Din Car DVD Player Receiver w Bluetooth/iPhone/Aux/USB
This has 5 RCA output channels (Rear L, Rear R, Front L, Front R, and Subwoofer)
3. 2 Pioneer TS-W261S4 1200W Peak 350W RMS 10" Subs in a vented box
4. 4 Stock speakers (unsure of wattage, size, etc)
5. Pioneer GMD8601 Mono Amplifier 1600W Peak
This has 2 RCA inputs (Left and Right)
6. Rockville RXA-F1 1600W Peak/800W RMS 4 Channel Amplifier
This has 4 RCA inputs
I guess before I go to far all I want to point out here is I have 5 inputs and only 4 inputs. What's the best way to put all this together without killing the sound (losing a left or right channel)?
The mono amp only needs one input to work.  You can split the single sub out on the HU into a pair of outputs with a Y adapter (such as single female to dual male at the amp).
the front and rear (left and right) should go to the Rockville amp and you should power the stock speakers from that Rockville.  They'll sound better than on the stock HU or the Jensen HU even though they are stock.  Upgrading them may be a good future task.
keep_hope_alive; I was thinking a Y adapter as well, I just wanted to make sure I wasn't going to miss out on any audio channels by doing this. I get there is no right or left technically in mono audio, but having them both was a bit confusing. Thanks for confirming, it's been driving me nuts for a while now.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
193
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
439
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Newb4Lyfe
CarAudio.com Newbie
Newb4Lyfe
Newb4Lyfe
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
