2 Channel Amp w/Big Bridged 4 Ohm Power
The_Grimy_One
Phoenix, AZ
Ok, so I am currently buying @ciaonzo 10" TC9.
It is single 4 ohm.
I will then need to purchase a 2 channel amp here soon. Looking for something that does between 800-1200 @ 4 ohms bridged.
Really curious what is out there to fit my needs. Thanks for any recommendations ahead of time.
Friend has a Zapco Z400.2 True RMS power
2 Channel H-E SQ Full range class A/B
Power @ 2Ω: 2 x 670 watts
Power @ 4Ω: 1 x 1340 watts
RMS Rated Power @
Power @ 4Ω: 2 x 400 watts
Bridged @ 4Ω: 1 x 1340 watts
RMS Rated Power @
Any idea what he may be asking for it?
So I can get that Powerbass or a Lanzar 500X2 for around $200.
Curious if anyone may have something closer to $100-$125. Used of course.
Though, may be best to go with new //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
134
367
10
744
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
833
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
The_Grimy_One
The_Grimy_One
Phoenix, AZ
350zspl
    Jun 1, 2024
    May 31, 2024
