2 older 2 channel amps
  • 4
05fronty
SALT PETER
11,937
conway,ar
kicker impulse 352xi
profile california a400xl
kicker used 7 out of 10 due to scuffs on paint and power terminal plastic side bent, tried to fix doesn't affect it
Power at 14.4V:
2 x 50W @ 4 ohms (0.085% THD)
2 x 70W @ 2 ohms (0.2% THD)
1 x 140W @ 4 ohms bridged (0.2% THD)
Power at 12.5V:
2 x 35W @ 4 ohms (0.085% THD)
2 x 50W @ 2 ohms (0.2% THD)
1 x 100W @ 4 ohms bridged very underated
profile is bnib. i have tested it and works
couldn't find specs
50 dollars for both picked up.
really don't wan to ship but may if i have to.
p><p>
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
134
6
366
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
744
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
441
05fronty
SALT PETER
05fronty
conway,ar
05fronty
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
