Crownvicon28s 10+ year member
God 1st
2 Stinger SPV70's
Used/Working. Resting at 12.9 straight out of the car.
Stinger's POWER Series batteries offer many of the same technologies as our remarkable Power2 series at an outstanding value. The valve regulated, sealed lead acid battery utilizes dry cell technology with an absorbed glass mat for performance that comes just short of the POWER2 but far ahead of other batteries! This makes the POWER series the perfect choice for excellent Dry Cell performance on a budget.
Internal resistance
5 Second Cranking 1050 Amps
Weight 57.3 lbs
Constant Discharge Capacity at 77 degrees to 10.50 Volts:
20 hour rate: 3.5A/70Ah
5 hour rate: 11.9A/59.5Ah
1/2 hour rate: 87.5A/43.75Ah
CCA: 875 Amps
DIMENSIONS
SPV70 6-7/8" H x 13-3/4" W x 6-1/2" D
(Add 5/8 to height for battery post)
General POWER Series Specifications:
Temperature Range: -15 to +50 C
Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
Maximum Charging Voltage: 15 Volts (Cyclic Use) 13.8 Volts (Standby Use
$100 plus shipping each (firm)
pm for shipped prices
2 Stinger SPV70's
Internal resistance
Weight 57.3 lbs
CCA: 875 Amps
DIMENSIONS
