2 Stinger SPV70's
  • 4
Crownvicon28s
God 1st
2 Stinger SPV70's
Used/Working. Resting at 12.9 straight out of the car.
Stinger's POWER Series batteries offer many of the same technologies as our remarkable Power2 series at an outstanding value. The valve regulated, sealed lead acid battery utilizes dry cell technology with an absorbed glass mat for performance that comes just short of the POWER2 but far ahead of other batteries! This makes the POWER series the perfect choice for excellent Dry Cell performance on a budget.
Internal resistance
5 Second Cranking 1050 Amps
Weight 57.3 lbs
Constant Discharge Capacity at 77 degrees to 10.50 Volts:
20 hour rate: 3.5A/70Ah
5 hour rate: 11.9A/59.5Ah
1/2 hour rate: 87.5A/43.75Ah
CCA: 875 Amps
DIMENSIONS
SPV70 6-7/8" H x 13-3/4" W x 6-1/2" D
(Add 5/8 to height for battery post)
General POWER Series Specifications:
Temperature Range: -15 to +50 C
Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
Maximum Charging Voltage: 15 Volts (Cyclic Use) 13.8 Volts (Standby Use
$100 plus shipping each (firm)
pm for shipped prices
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
