2004 Avalon Subwoofer Repair
scottjoe345
Hello, new to this forum and car audio in general so sorry if this is in the wrong category. Need some help fixing my subwoofer.
Got a used 2004 Toyota Avalon about 2 years ago and about a year later the factory 8 inch JBL 86160-AC180 subwoofer blew out. Just makes a loud, annoying rattling noise so I've kept it off since then and have put off getting it fixed.
Now, looking at other forums it seemed like the problem is that the foam around the cone deteriorates so I took out my woofer and of course, that seems to be the problem.
The fix according to the internet is just to refoam, but when I call up the local audio shops they all say that I need to replace the entire subwoofer which costs about $300!
So my question for everyone is whether this refoaming fix is legitimate or the local shops are just trying to scam me?
Thanks for bearing with me.
Replace it with an Image Dynamics id8 v3 d4. They run Ib and sound great. Do it yourself and its a $99 dollar project. Wire it in parallel for a 2 ohm load which will match your jbl factory amp.
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
scottjoe345
scottjoe345
Atlanta, GA
Jes 42
