2004 GMC Savana Conversion Van Replacement DVD
  • 2
Savackz
GA
Trying to help out my dad that has a 2004 gmc savana conversion van by replacing the dvd player with a newer one and was looking at the wiring. Has a green cord, an orange cord, and a black ground. I figured out that the green is power, and the black is ground, but still confused on the orange wire. The new units only have a power and a ground on the factory harness that comes with it. Any ideas? Can't find a factory replacement, so have to go aftermarket.
Did you cut the factory plug off? If not just get a wiring harness adapter plugs into the factory plug and gives you color codes wires that will match up to the aftermarket harness.
If its like my Yukon you will also need to run an accessory wire from the small fuse block in the drivers foot well near the ebrake handle.
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
Savackz
Savackz
GA
dbjunior
    May 18, 2024
    May 16, 2024
