2004 Grand Prix Remote Start?
  • 2
96Cherokee
I have been trying to install a Codealarm model F50/F55 in this 04 Grand Prix. After testing the connections and 2 brains, I have found nothing. All of the connections test correct (and yes the correct pink ignition wire is being charged for those of you who know about that.) The unit when activated will charge the accessory wire as to turn on the said circuit. When it is time for the starter to crank, there is a split second sound as the beginning of starting, but it does nothing after that...the unit has a bypass module that tells me it has been programmed correctly. I am at a loss for words. My experience is with DEI and code is different. Please help.
yes tach is in, All wires from a standard RS are in.I have tested all of these wires multiple times and they test correct. There has to be something I am missing.
After reviewing the wires once more...the technician on the phone from Code said that there WAS a second ignition wire that needed to be charged. BULLSH!T!!! The brake wire in this car has a resting voltage that caused all of this. Simply wired in a relay instead of direct wiring and there we have it! To all that may have this problem in the future, here is a good starting point!
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
96Cherokee
96Cherokee
Bum F@ck, Egypt
96Cherokee
    May 18, 2024
    May 16, 2024
