2004 Lincoln Navigator with THX audio Aftermarket install help
  • 1
twobears29
I have a 2004 Lincoln Navigator with factory Nav and THX audio. I purchased a Blaupunkt San Diego 530 Nav Receiver from Crutchfield. They threw in a Metra 70-5520 wiring harness. The issue is that I wired up the harness to the receiver and I have no sound whatsoever. There is a 5520 factory wiring harness but also 3 16-pin harnesses that I'm assuming is for the amp, speakers, nav (which I'm replacing with the Blaupunkt receiver), but I noticed that the Metra wiring isn't matching with the factory wiring and can't find a harness that is compatible with my factory speaker system. I'm not an car audio guy, so any help would be appreciated.
Factory 16-pin Connectors
Factory 5520 Connector and wiring
Metra 5520 Connector and wiring
Update: Turns out I have to completely bypass the THX amp as there is no integration. Axxess use to produce a THX integration interface but discontinued. I have to wire directly to the speakers from the Aftermarket receiver. Anyone having a problem with this same issue here's a link to the wiring information. http://crutchfield.custhelp.com/app/answers/detail/a_id/5941
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
twobears29
twobears29
Fruita, CO
twobears29
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
