Central Region 2014 minnesota midwest spl competitions
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
  • 2
Anton Miller
With a progressive point event, either second or 3rd show.
2014 MN MW SPL Dates
MAY 18th
JULY 20th
SEPTEMBER 21st
LOCATION
Rigs To Rods Service Repair & Performance
900 State Hwy 24
Clearwater, MN 55320
Rigs to Rods
Rigs to Rods , Clearwater, Mn | Midwestspl
Rigs to Rods , Clearwater, Mn, #2 | Midwestspl
Rigs to Rods , Clearwater, Mn, #3 | Midwestspl
Tel: 320-558-4660
Fax: 320-558-4477
rigstorods@gmail.com
MIdwest SPL. has tons of classes. it is an spl org. no sq classes. basically you pull up (local classes) get your loudest song ready, play it for as long and as loud as you want with the meter in your car (technically you only have 30 second to post the highest score you can) then you go against other cars like yours, they have trunk classes, all the way to wall classes. broken down by cone area mostly then power as well in the national classes.
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
980
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
680
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
986
Anton Miller
Anton Miller
Invergrove Heights MN
mrbadwrench
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
