3 amps
  • 1
Hello all. So i decided to upgrade again. Now im getting worried about my cars electrical system. Im doing a wiring upgrade. Aka the big 3. Using 0 awg battery cable. Ill leave the factory wiring and add to it. Its a honda accord and stock alternator puts out 130 amps max. Ive got 2 amps bridged that's rated at 1800 watts cea at 4 ohms. And a 1200 watt max 4 channel that's probably doing a hundred per channel really. So lets say 2200 watts total. Best i can figure is ill use the shops amp meter and crank up the system and check amp flow that way at the battery? Before the new amps went in i was using the 4 channel and one 900 watt amp and i did notice a bit of headlight diming at full volume. The new stuff should be way louder and ill probably only approach max volume when im showing off... lol any body have any input as to car electrical upgrades? Anyone think ill need it?
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
352
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
511
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Fathershelper
Fathershelper
San Tan valley
Fathershelper
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
