3 JBL GTO804 Sealed
Looking to put subs behind my seat of my 2001 Nissan Frontier Crew Cab in a sealed box. Each sub needs at least .3 cu ft but box is at .85 cu ft and i cant make the box any bigger. Would polyfill help to get it at its minimum specs?
Box Dimensions
Depth Top:3.5
Depth Bottom:6.5
Length:48
Height:1.5
Approximately 1 pound of polyfill should do the trick for you. You could always try a little more or a little less depending on how it sounds to you. You are gonna love those GTO804's. I got 2 in my car and they sound great.
Box Dimensions
Depth Top:3.5
Depth Bottom:6.5
Length:48
Height:1.5
Those are nice subs...I run a pair in my 76 Stingray ...
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
KuruptYoMind
KuruptYoMind
United States
Louisiana_CRX
    May 18, 2024
    May 18, 2024
