4 sub's, having a problem with 2
  • 2
beartoe
I have four kicker comps on 2 900 watt 2 channel amps. I have them split off one power wire with a dist block. Two of them work fine on one of the amps. On the second amp, when one sub is connected, that one sub works fine but when I hook up the second sub on the second amp, both subs move but put out no bass. I have tried bridging the amp as well as running them in parallel but it does the same thing. Is there something wrong with the wires or amp or subs? The second amp is new and so are the sub's connected to it. Any help with this issue would be greatly appreciated.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
140
286
465
577
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
908
beartoe
beartoe
Baton Rouge,LA
beartoe
audiobaun
    May 19, 2024
    May 19, 2024
