4th Order blow through for 10 12s, 87 Chevy long bed
Little update. He got all new door and window seals/felts and new door panels. He took his truck to the Chevy house to have some work done, picked his truck up and the T2000 isn't working. Fuse not blown and nothing burnt inside but won't power on. Soooo, he has Skar 2500 on the way //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Also got the Mechman 240 in
Hmm, that blows on the amp not working..Someone prob jacked with it??good thing he has a backup amp on the way.I just had my truck picked up, and pulled the ANL fuse out,to get the trans redone.Keeps peoples from messing with my chits!
//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
---------- Post added at 11:11 AM ---------- Previous post was at 11:10 AM ----------
Love this build OP, **** I can't wait to have my Blowthrough back in
Ok got a vid. So three things have changed since the T2000.
Deadner on floor and doors
Mechman 240
Skar 2500
Deadening raised the peak hz a tad. Now peaks around 32 hz.
At the first of the video my finger was on the mic.. This thing is ridiculous for some Kenwoods. We're going to a show tomorrow, should have some numbers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
power-fanatic07
Knockin Doors Down
power-fanatic07
Texas
power-fanatic07
    Jun 1, 2024
    May 31, 2024
