6.5 speaker input
  • 1
ender2664
CarAudio.com Recruit
2022 Camaro with Bose:
I have KICKER 47KSC6504 6.5 Inch speakers in the passenger sail pannel.
Would switching to TIMPANO TPT-MB6 Slim help get more base without tunning?
Example:
At 80hz will the timpano produce more midbass (air movement) than the kicker? Or is it just the ability of the timpano to be tunned differently that makes it classified as a midbass?
I'm using a AudioControl LC-6.1200 amp, if that matters.
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
265
360
331
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
ender2664
ender2664
California
ender2664
    May 16, 2024
    May 16, 2024
