6.5 sub
What all do you have audio wise in it now ? I always like something decent in a work truck because your usually spending a lot of road time in one ..
Nothing now. Planning for a 10 per door with a tweet getting about 300w per door. I have a 10" AA sub, (2) sundown sd10's laying around but i'm very interested in trying smaller subs for this setup. I prefer to ride in the work truck than my daily car honestly. simple, paid for, rugged, ect...
I put two Kicker Resolution 8s in the doors of my 84 S10 ..it’s an extended cab and I’ve about decided on 4 DD 8s in it for substage ..each pair on separate amp
My son has a single cab 2000 GMC Sonoma and I'm curious what could fit behind the seats too?
Two 6.5 subs truck style box subs side by side drivers side ..run box across back remove jack parts on back wall ..load port 8” off passenger corner ..make sure box is built to specs ..disconnect rear speakers
Don't see anybody using CT Sounds subs....kinda makes you wonder why.
Seen Massive Audio 6.5" subs being used as well as Sundown ones.
Which seats does he have? I've seen everything from sealed 10's, 12s to a 15. Ported 6.5s, 8s, 10 and a 12. Depends on the seats and how much room you're willing to sacrifice.
Sealed? How does it sound? loads well in a single cab?
Got a pair of SD10's that I wouldnt mind using sealed. I'm a ported guy...
It sounds good to me ..I’m 6ft 230lbs and sit comfortably in it ..the amp is a 3ch JBL 500@2 on the sub ch ..those are older Polk Momo 10s they were the last series ..not as well made as the first and 2nd but do have a good sound
438
462
568
698
oryan20xx
oryan20xx
WA
Papermaker85
    Jun 1, 2024
    May 31, 2024
