8" sub recommendations
As far as that QPower box goes... best I can come up with for the type S is 1.92ft3 AD, and the port length uncorrected is 13"?.. that's 36.78hz and according to Winisd gets to 100fps port velocity on around 265 watts input. That's around a 360 watt amp according to how I read it. Probably actually tuned to 37-39hz, with the drivers firing down and the port restriction you'll likely lose a lil' output. But I've seen worse believe me.
Whew....glad it doesn't look too bad. Hopefully it should be okay for what I'm looking for. I don't want to blow my windows out, but just get some good clean accurate low end.
Is that the old type s or the new type s series they just came out with? Idk how much they changed from the old 1.They just recently released them so he maybe able to find a deal on the old ones.
I'm getting the last model (SWS) when it changed to look like the Type-R. I should be able to get both for $150 or less as opposed to $130 each for the new ones.
It might be adequate for your needs but when I said "a lil'" output loss and I've seen worse... sure, but please don't take that a an endorsement.
Prefabs generally don't get low or rowdy in my experience.
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
431
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
436
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
563
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
687
tooshort_128
tooshort_128
Sterling, VA
shredder2
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
