A Head Unit in a 2000 Mitsubishi Eclipse GT
  • 3
warfront1
My current stock infinity system is ok.... But the cd player doesn't work all the time, and the tuner sounds like garbage..
When the cd player does work it sounds reasonably good...
Right now I'm trying to switch out my headunit just to be able to play cd's and ipods..
So does anyone know if I will run into any problems, because I have heard it is a pain to go from stock to a new system in this car.
Also if anyone has links to a picture diagram of the cars wiring that would be great, because I plan on putting a new system fully in within the next month.
I "had" the infinity system. I just stripped the wires twisted them together and tapped the hell out of them. Works perfectly fine. No extra gear needed at all besides some old wirecutters and some $3 electrical tape. It now runs the stock tweeters and center speaker along with my 2 Hifonics amps for my aftermarket Alpine mids and Kicker subs.
6
366
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
679
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
748
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
919
warfront1
warfront1
swedsboro, NJ
R34P3R
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
