Able To Get My Sub Repaired?
  • 3
SoCaL081
50
I got a Eclipse SW8122DVC sub in a trade and ended up getting screwed by the guy. I didn't test it out first like a jackass and when I went to hook it up, nothing... I compressed the Cone to see if there was any scratching or any noise and jt sounded fine. Well I removed the magnet and found the aluminum voicecoil/former was ripped 80% around it. I'd like to get it repaired if possible. Does anyone know where or how I can get it repaired? I'd really appreciate it if you guys can help. Thanks
No coming back from a broken former. On the bright side the TC9 is a fantastic platform to build a woofer out of regardless of your intended application. I've got a couple OEM coils for those back up north but I won't be there for another month probably.
How much for one?
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
488
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
520
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
623
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
761
SoCaL081
SoCaL081
hispls
winkychevelle
    Jun 3, 2024
