Active LOC Wiring help
  • 2
pixtondan
CarAudio.com Newbie
I’ve recently purchased a bunch of equipment from crutchfield for my 2020 Tundra. I wanted to keep the stock head unit, so I purchased an AudioControl LC2i PRO LOC. I’ve figured out the wiring for my amp and subs, but I’m a little lost on where to pull my constant +12V power from. I’ve seen videos of people using power from the head unit, and others have told me I need a 16AWG power wire to the battery just for the LOC. Any help would be greatly appreciated.
I just installed my LC2i last weekend and I tapped into my passenger kick panel fuse box. I used the factory amp fuse to tap in to. I got these from Amazon and they worked great:
10 Pack - EPAuto 12V Car Add-a-circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder https://www.amazon.com/dp/B01DYQM6EO/?tag=caraudiocom-20
Alright, so bear with me. This is my first ever audio system, so I’m a little lost. So you tapped into the factory amp power wire coming from the fuse box?
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
588
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
963
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
So, assuming that you aren't using an LOC and are using the hi-level (speaker) inputs, use the speaker leads off of any of the R/L speakers (front...
39
4K
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
775
pixtondan
CarAudio.com Newbie
pixtondan
New Orleans, LA
Marve_Lous
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
