AHHHH Why wont it work?
  • Thread starter Ktulu282
  • Start date
  • Replies 1
  • Views 1K
  • 1
K
Ktulu282
Guest
I'm using Blaupunkt Hamburg series receiver. Im using the sub-out on it. But should the regular speakers still get lows? It seems not all the bass is being sent to the subwoofers, instead being sent to the speakers too, and its all distorted too, even worse then before. Any ideas what I can do?
yea your other speakers will still get bass. here is some thoughts and questions.......
1. r they your factory speakers?
is a high output unit?
have u tried turing the bass down on the stereo?
is that where the distortion from?
they could be shot.
2. actually, that's all i could think of, unless there is distortion coming from your sub as well. that opens up a new can of worms!!
ps. u could always go to bass blockers on your other speakers. i don't believe that their expensive or hard to install.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
That's the dd1 The dd1+ has only 4 tracks. I have the dd1+ , just got home. I think the dd1 has all those other tracks. Diff tool. So it says...
9
Id remove it at this point and bench test it on 12v
6
Guest
mrray13
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
