Alex's uncles' amps
Not sure if Stetsom still makes 4k2D but I really liked that amp when I used it, Legit power, ran cool, and small footprint.
Assuming your uncles aren't veterans with car audio you really don't want to put them into 5kw into a pair of those subs. They will break stuff fast.
They had old school gear, but nothing close to as big as what we have now
Well, VM subs are shite, this amp looks to be able to do around 2-2.5K rms maybe. I'd trust a Skar 2K long before this amp, or find a used Synergy 15.1, or TS 1.8 ....
Yeah, I think I'll be going with the Skar's.
Now, I need to figure out the alt situation. My 320 amp Singer hairpin fits the 71 Firebird bracket, but the stock v-belt pulley has a slightly larger inner diameter than will fit on my 320 spindle. Not sure if there is a v-belt pulley that will fit on the 320 spindle, or if it's possible to use some type of cone washer on each side of the pulley, and torque it down.
349
509
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
    May 31, 2024
    May 24, 2024
